turbolude
- Jan 23, 2005
im trying to find out if any has an opteron 146 that can hiot 3100-3200+ on water i think ive seen some out there but idk. also with volts around 1.5-1.6ish. and what steppings
turbolude said:well i have a 148 but i dont think the memory contoler is as good as some 146's its on water also and hit 42c-45c max and can get it anymore stable then 3045 i guess it cool go higher then that on a phase unit but from some charts ive seen there was a few i think on water hitting over 3100-3200 so idk maybe they are bsing everyone. and they are newer steppings. it could be somther things holding me back possibly my mobo but its a DFI UT SLI DR. Expert would be better since u can increase all volts like in tenths
don't really want to call you out on this, but are you sure? is 2.75ghz close to the limit in your board with 1.45v?mchlhotrod said:I am actually selling one in the For Sale/Trade Forum here:
Opteron 146
Will do 3.0+ Ghz with good mobo/cooling, had mine in an Asrock mobo (not very good for overclocking) and a Ninja heatsink and 120mm medium speed fan running 2.75 Ghz with 1.45 volts
(cf)Eclipse said:don't really want to call you out on this, but are you sure? is 2.75ghz close to the limit in your board with 1.45v?
for reference, my 146 CABNE can do 2.95ghz with 1.45v, but needs ~1.52v with normal opterating tempteratures to get 3ghz stabilized.
turbolude said:running 1.54v daily around 3ghz safe for long term with temps into low 40c?
turbolude said:yeha just wanted to make sure thanks
saying that a cpu may do a certain mhz in a FS/FT thread when i'm fairly sure it won'tmchlhotrod said:im using an Asrock DualSata Motherboard and the voltage only goes up to 1.45 on it the highest i got stable was 2.83 and that was also hindered by my power supply
CPU-Z Link to 2.83
I know have an X2 4400 and new power supply along with the vcore mod for the Asrock board and have not tried the 146 with this new configuration but im sure it would do 3+ Ghz and what are you calling me out on?
