Opinions on WC Setup
wheels2040
I am thinking about going WC, and have assembled a list of parts. Would like some opinions. Will be trying to get some good OC'ing results.
Asetek Waterchill Antartica CPU Block
Asetek Waterchill Antartica VGA Block
Swiftech MCRES-1000A Pump/Res Combo
Swiftech MCR-120 Radiator
Swiftech Radbox MCB-120
I thought of going with the whole Swiftech kit, but I have seen alot of complaints on here about the low quality of the newer Swiftech blocks. Space is an issue as I only have 1x80mm in the rear of the case and 2x80mm right in front of the drive cage. Any suggestions would be appreciated.
From the reviews and testing of the Asetek blocks that I've seen they seem to perform pretty well, matching the TDX and RBX pretty closely.
However, a friend of mine had the Antarctica CPU block and found it to be crap. He got a couple of degrees off his load temp by going to a storm instead.
I was just looking at some stuff over at DangerDen. Looks like pretty good stuff. Looking at the Maze4 blocks.
