I am considering the following upgrade to my system and would like some insightful opinions on whether i'm doing it right:
x2-3800, a8n32, in a P160 case. non-OCed (with no intention of doing so either).
I want to put two Yate Loon 120mm fans in - one for the front, one for the rear.
Place a Ninja hs to replace the stock and put a coolermaster 120mm fan to blow air to the rear fan
Probably will go with AS5 (instead of ceramique)
Does this sound like a decent setup? my goal is to maintain current temp loads (of course lower is better) but more importantly reduce operating noise.
thanks for your help
