Opinions on Case
Railroad
Hi,
I'm debating whether to get the Plus or Plus II version of the Lian Li v2000(possibly 2100) case. They're both priced at about the same from where I can buy it. Would the side fan on the Plus II cool better than the Plus? Also, the holes on the v2000, would the inside of the case collect more dust than other cases? Any advice would be appreciated.
Thanks in advance.
I was looking for a long time too and I would go with the Plus 2 series. More air flow, better designed. I ahve an original V2000 and it's great, but the plus 2s are where it's at for cooling I think.
Thanks for the reply.
I'm sorta leaning towards the Plus II. I mean, I'm buying something this expensive already, might as well get something better.
Anymore opinions?
Thanks.
