Opinions for new system
I am working, on a budget, on getting together prices for a new design station for work. I work at a sign shop where we use a sign software called FlexiSIGN, as well as Photoshop, Illustrator, AutoCAD, and others. I am currently working away on dual Athlon XP 2400s with 1GB ram, and plan on goin with Opterons for the next computer.
The computer so far without MB, CPU or RAM, is coming in around $725.00, and the at most cap is $2000.00, the closer to $1500.00 the better. Aside from going with Xeons, possibly, the two options I am looking at are either Opti 246s with 2GB of ram, or Opti 242s with 4GB.
So whats everyones suggestion? And ideas on the Xeon side are welcome, I have been a die-hard AMD fan but I am not against looking into Intel if the price seems right.
already on dual MP2400+'s...nice...i went the cheap route and modified tbred-b XP's and clocked them up to 2348mhz...
the 246 combo will put you slightly over your 2k limit (using the MSI board and retail chips w/corsair 1gb dimms)...not by much, but it will nonetheless...it should be plenty powerful for you...2GB of ram should be enough for all but the most graphically intense images you're working with...
The cheapest intel route right now is a pair of 1.6LV xeons and overclocking, but since this is for work you prolly wouldn't want to do that...most 1.6LV's will do 3.0ghz with modest air cooling and they also support HT so that's 4 threads total...if i wasn't so broke i'd build one for myself....
