Opinion on setup and question
Here is the setup I'm currently looking at:
Danger Den Dual 3 1/2" Floppy Bay Reservoir: $24.95 https://www.dangerdenstore.com/product.php?productid=54
Copper TDX Block for AMD Motherboard Socket Tabs: $63.85 https://www.dangerdenstore.com/product.php?productid=18
Danger Den CSP-MAG 12 Volt Pump: $49.99 https://www.dangerdenstore.com/product.php?productid=178
ClearFlex 60 Tubing 1/2" ID 3/4" OD: 5ft. @ $6.25 https://www.dangerdenstore.com/product.php?productid=61
MCT-5 Non-Conductive Solution: Free https://www.dangerdenstore.com/product.php?productid=144
Weapon Radiator and Shroud: $65.00 http://hardforum.com/showthread.php?t=846570&highlight=shroud
Evercool Aluminum 120mm Fan: 2x $23.90 https://www.dangerdenstore.com/product.php?productid=124
How dose this setup look, I'm looking to stay within a $250 price range for this setup.
And for a question, is possible to put the radiator 1 or 2 feet away from my case without sacrificing proformance as it dosen't have suffencent room for it to be mounted inside or outside of my case with a bit of modification.
Thanks
would get more hose if you are going to mount the rad "off the box".
the 1/2 id tubing will make that possible, I doubt you would ever notice it.
I too would have some (but not a lot) concern about the pump, as there is no P/Q curve for it that I can find easily to show how well it deals with resistance in the loop. The good news is that you can get a dual mount and run two of them and they are small. Here is the people that make it, http://www.c-systems.ca/
I've noticed these Csystems pumps too and even the reviews of the discontinued 750 looked pretty good, and that small size is really nice. Finish looks good too.
Russ said:
http://dangerdenstore.com/product.php?productid=170&cat=69&page=1
save some money and get a better pump.^^
Other than that, great setup. I'm sure it will be fine to put your rad far away. It will just require a little more tubing, so cooling will be slightly weaker. Just try to minimize tubing in the other parts and you'll be ok.
I will get that combo instead, its a good deal. How loud is the D5 pump?
wwparrish said:
Doh the review has all the tech data you will need as well as good general info on pump design considerations.
http://www.systemcooling.com/cs_pump-01.html
Nice little pump and two of them give huge flexability in "playing". Might have to get me a couple.
I wish I could find more info. on the use of dual-pumps in various configurations vs. other single pumps....for example, 2 CSs in parallel, 2 CSs in series, 2 CSs in semi-separate loops, all compared to like the D5 and DDC...
