opinion needed of current PC !!!
shkj
Hi All,
I have been posting here for about 10 months now asking tons of questions about my current PC....and if it is a good photoshop/photography PC and if it is worth upgrading it to a dual core or just build somthing new !!
well now it is crunch time on what to do !!!!
here is my current configuration:
Asus socket 939 motherboard (A8V Deluxe)AGP,
AMD64 3200+(VENICE CORE)
2 Gigs of DDR400 low latency RAM with timings of 2-3-2-5 (Patriot PDC2G3200LLK 2GB Kit DDR400 PC3200 Dual Channel Memory (2) 1 GIG sticks
Western Digital Raptor 74 gig 8 meg cache drive for my O/S and APPS
160 gig Hitachi sata drive for my data in a USB/firewire box for data
my Windows XP paging file is on an 80 gig seperate drive
my Photoshop scratch disk is on a Western Digital 36 gig Raptor drive all by it self
256 meg X800 PRO Ati Radeon video card
(1) Dell 2407 24" LCD MONITOR and a 20" Planar LCD MONITOR
Basically is it worth it to upgrade my current system to an Opteron 180 Denmark 2.4GHz 2 x 1MB L2 Cache and be done with it about $280
OR
build a new Core Duo2 system re-using some of my old parts...i should only have to buy a new processor (E6600) 2.4GHz 4M shared L2 Cache
MSI P965 motherboard & 2 gigs of DDR2-800
THIS MACHINE PLAYS NO GAMES IT IS USED ONLY FOE WINDOWS STUFF,RIPPING DVD'S AND DIGITAL PHOTOGRAPHY !!!!
I want this to be a performance machine but at the same time trying to be budget conscious !!!
Well, the real thing to check would be to see if any of the software you use it multithreaded. If it is then it would perhaps be worth upgrading or building a new system.
I don't notice much of a difference from going with my 2.4GHz single core A64 system to a 2.49GHz e6300 in photoshop. There are a few instances where I can really tell, but not very many to tell the truth.
I'd wait for the software to be multithreaded before I went dual core if I were you. (Though the new version of photoshop may be, I'm using a fairly old version) When it does you'll be able to get an even better cpu than what's out now.
i was going to tell you to wait a little while and get quad core, when the price drops, if photoshop is multi threaded,..but i just realized you are going to need to also upgrade your video card if you are changing out your motherboard. and thats another 200 dollars for a 8600 or somthing
