Operation P-180
AragornTK
I'm trying to think of mods for my newly acquired Antec P-180
http://www.antec.com/us/productDetails.php?ProdID=81800#
I'm thinking of taking out one of the two fan filter enclosers and putting in 3 little text LCD's to display temps, fan speeds, etc. and maybe the stats for my games like on the Logitech G15... I'm getting one soon, i'll just figure out what wire does what and use an internal USB to power and run it.
Also I want to put in a window... just a simple window that won't take away from the industrial beauty of the case.
You will have to be very creative and industrious to readily mount anything if you remove a fan filter enclosure in this case. In front of the filter is a plasic door that will have to be carefully chopped or completely cut out, exposing the case frame. Behind the filter is the steel screen which is part of the case frame. Behind the steel frame (once you remove the fan) is nothing that will support anything. You'll have to do a lot of modding to make this project really work.
Working on a P180 mod myself. Can't wait to see what you come up with!
