I found out about a great program for the PSP last night which lets you run ANY Java app for cellphones on the PSP.
Check it out: http://sourceforge.net/projects/pspkvm/
OR the project page: http://www.pspkvm.com/
After that, you can install the opera mini browser ( http://sendspace.com/file/7jf9n2 )
1. download both files above
2. extract pspkvm to the ms0:/PSP/GAME directory and the opera mini in the ms0:/PSP directory
3. now go to the game section and run pspkvm
4. (NOTE: use circle to select, start for bottom right option, and select for bottom left option)go to find applications and then install from memory stick
5. locate the opera mini browser you downloaded and select it
6. it will ask for the preferred device, so scroll all the way down and select Sony Ericsson (480*272)
7. after that, it will install and you will see the start page, it will also ask for airtime, when it does just select yes and you can choose your wireless connection
Opera mini is recommended over the built in Netfront PSP browser as it is much faster and renders pages real quick, even with image heavy webpages!
Source: http://psp.wijou.com/forum/index.php?showtopic=803
