Opening A WD Elements 1tb desktop Hard Drive
jznomoney
Does anyone know how to open the case on a Western Digital 1tb Elements drive model WDBAAU0010HBK-NETG?
I figured it out. It was easier than I thought. Now screws held it together. The case just slid open lol.
Is this the one from Target? wdbaau0010hbk? How did you get it open? Which way did it just slide off?
The only seam is on the bottom from what it seems. I wanted to get it out without damaging the case.
Well, I just dived in and tried it. If you use an exacto knife or something similar you can slide in on the bottom around the seem. I just went all the way around with that, and then did it again but gently pried outward a bit, and it popped off.
