OpenGL more intense than DirectX?
cfetter79
Running machine in sig. Have a VGA silencer on the 9800 pro. I'm getting (mild) artifacts in D3 at stock speeds, whereas I can run say, FS2004 at 410... is OpenGL more intense than DirectX or is it just that this certain program is so intense?
Thanks in advance.
as carmack said your gpu will be using transistors it's never used before.
