Open NAT
AVAFREAK182
I have a D-Link DIR-615.
I need the NAT open to play with certain people on XBL.
How do I do it?
Well, it should give you the basic idea of things.
1) Setup your xbox with a static IP address. (manually configure it in the network settings on the console if your router doesn't support static DHCP leases)
2) Forward the following ports to that IP address.
* TCP 80
* UDP 88
* UDP 3074
* TCP 3074
* UDP 53
* TCP 53
