Only partial GPU usage in Collatz
Mr. Pedantic
I just started running Collatz on my 4870, but it's only using ~26% of the GPU. At the moment it should take around 25 minutes per WU, does that sound right?
Collatz has two types of WU's. They have a mini and a regular. The mini takes only a few minutes (<5) to complete on a 5850 and a regular size WU takes about 25 minutes.
Are you running the latest BOINC manager?
Yes.
All my finished WUs took about 26-27 minutes to complete. Except under Application it says they're all "mini_collatz 2.09 (ati13ati)"...
My current WU says "collatz 2.09 (ati13ati)" and it's taken about 1.5 hours for 40%.
I think I was having similar issues. Check the Collatz forums. I believe there is an optimized client and command line settings, etc. It all seemed really complcated to me so I didn't try to tweak it, but I was only running Collatz short-term.
You may also need to try a different driver version. It seems like a lot of BOINC projects prefer older ATI drivers.
