Only need little help.
BioInclined
A lot of WoW play, A lot of web browsing(while playing), minor CAD work, minor media use.
Lower better, not my money so can't really say exact.
3) Where do you live?
Chicagoland
CPU, PSU, Mobo, GFX card
Using a Coolermaster Storm case, G.Skill 4GBx2 1600 RAM
6) Will you be overclocking?
No
Have a 22" Gateway
Slowly gathering parts, no rush. By early December for sure.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
Nothing necessary
Will be using Win 7 64-bit
Well two things.
One, we really need a budget to recommend parts. Secondly,bump this topic the week you plan to purchase the parts as most of our recommendations are based on monthly deals that change very frequently, in an effort to get you the best for your money, it's best to order everything at the same time.
Assuming that monitor is 1680x1050 resolution?
