Only 4528 06 3D Marks? CPU test horrible...
DragonTG
So I just recently upgraded (x1900xtx ati, amd 64 4400+ x2 proc, asus a8n-32 sli deluxe, and my old 512x2 corsair 2700 RAM) and I just ran 3dmark06 with a freshly installed and upgrade version of windows xp, with catalysist and mobo drivers all installed and I only get and the CPU tests were absolutly horrible! I don't think I saw the FPS go above 0!!! Is this how it is supposed to be? The graphics tests were fine, somewhere in between 20-30 fps.
I'd appreciate it if someone could tell me there thinking about this, and maybe how to make it run better! (could the RAM be the problem?)
Heres my scores in depth:
4528 Marks
SM2.0 Score: 2165
HDR/SM3.0 Score: 2330
CPU Score: 862
I averaged 16.6 in proxycon, 19.4 in firefly forest, 22.76 in canyon flight, 23.8 in deep freeze, and GET THIS 0.27 in redvalley1, and 0.44 in redvalley2.
Thanks for your help guys!
The CPU test is meant to be that low, it is locked at a framerate, even with the fastest multi-processors available it will only reach around 1.5 FPS. Don't worry about it, it doesn't mean your system has a problem.
In fact, play some games and see how everything performs in the games you play.
Is it possible that my processor is acting like its not dual core? How would I get dual core fixes?
Open up task manager and see, click on the performance tab, if you have two graphs under CPU usage history you are using dual core
Alright guys well ****! I got home and did the AMD.com forums update (posted above) did the hotfix, etc. Even device manager says there's two processors. I also updated my catalysist drivers to the newest one from the ones that came on the CD. And low an behold only my graphics scores went up:
Here are the old ones:
4528 Marks
SM2.0 Score: 2165
CPU Score: 862
Here are the ones I just got:
4780 3DMarks
SM2.0 Score: 2290
SM3.0/HDR: 2581
CPU Score: 862 !!!! EXACTLY THE SAME
Very weird.. what could have happened? OH and BTW Before I updated the processors I didn't know if it really needed it or not, I never checked.
Funny, but I just tried 1gig of my friends OCZ 3200 RAM (one stick) and it was actually lower (and the one I was using before is only 1gig too (two sticks))
4758 marks
and only 857 cpu score (and the graphics one are alittle lower) so what should I do?
Something is still wrong there, I get ~5k with my X1800xt.
My CPU score is 1927.
Most importantly, do you get low performance in accual games? like HL2, BF2, or FEAR?
Is it just with 3DMark06, then dont worry about it, it's not a game...
Well I mean I wan tthe best performance possible in game or I wasted 300 bucks on a dual core
read the forum...i dont believe there any games that support multithreading anyway...dont quote me on it...
its not really a waste.. when ur consider what can be done over a single core...
plus like the others have said 3dmark is just one thing.. try it out man. play some games,,, mess with it. go crazy :)))
In CPU test 3Dmark2006 uses just one core.
0FPS is normal.
MD
the fps on the cpu tests dont matter. i get 0 most of the time but my cpu score is around 1800. to the OP, try reinstalling windows and then try the dual-core drivers again. u should be getting around 1500.
Something is wrong there. On my system I scored 4802 in 3dmark06 with 1012 CPU score. I'm not overly familiar with 06, but I know in 03 that I was getting about 7000 marks too low because I was forcing AA and AF in the drivers. Check to make sure those are off and run it again.
You wasted $300 on dual core then, if just for gaming. There are almost no multi-threaded games out there, sorry.
yes, but its all in the cpu for the cpu score, which is what he posted about. not about fps in the cpu test, or dual core or drivers. just that his cpu score is way low. which it is.
Dual core is not so great for gaming; you have to install the proper amd drivers and hotfixes to even get it to work properly. On top of that you may still find random stuttering in games.
Check the link posted earlier, it has all the fixes and instructions.
