Does anyone know a website that has a good and thorough reference of standard functions and libraries in C/C++? Or a good suggestion for a reference book? Currently I have "Absolute Beginners Guide to C" but it doesn't seem very good. The majority of the books content has been discussed in more detail by my professor in class.
I seem to get stuck with built-in c functions. Currently I'm trying to find the length of an input value of type unsigned long. Is there a built in function for this, because strlen doesn't seem to work? Do I need to put the input value into a string before I can find its length? If I remember correctly I must define the length of a string at compile time, so do I need to set its length to the maximum length string on a solaris system? The maximum value of an unsigned long is 4294967295.
I really don't have a firm grasp on stuff like this, any suggestions of books/websites to read so I can better understand input/output, data manipulation, and other important concepts? My notes just don't fill the gap.
Thanks
Thanks
