Onetime use 10% off XPS systems.
MrJohnson
I have one coupon for 10% off of all Dell XPS desktops and notebooks. I'm not in any finacial position to use this so here you go.
2JCJMJ0XZVZLFV
Make sure to post that you've used it when you use it. Thanks.
You might wanna remove the code from public view and instead instruct that anybody interested send you a PM. It'd help avoid any problems with two people ending up using the code within the same time frame.
just about to say that
Its one time use.. should be immediately voided when the coupon is applied to a cart...
