The GUI has changed since I last folded, but I remember there being a one unit mode to where a CPU/GPU will stop folding when it finishes the current unit. Is there a way to turn that on still?
You could also go into advanced control, click configure, click on expert tab. Add "extra client option"
max-units 1
Save
The option will need changed to a higher number and restarted or just restarted after the max-units is completed before it will grab another WU and start folding again.
as others have said, right click and choose finish, just remember though the next time you reboot your machine, the slot will start work again as normal.
