So I'm using a gigabyte GA-EX58-UD4P on a new build and when I go to power up I get one short beep and then the system shuts off. I'm only posting because the mobo manual doesn't have a code for just one beep besides that it means the system has booted successfully.
I suspect it might be the graphics card, but not sure. I would like a little stronger evidence before going for an RMA.
So, what should I try?
Thanks.
Thanks.
