Nov 4, 2006 #1 J jordan12 [H]F Junkie Joined Dec 29, 2000 Messages 11,105 I am looking to overclock my 6800 go. It shows me Memory clock and 3d clock. Which one is the core memory? I want it to run at ultra speeds, which is 450/550 So which one is set to which number? that is what throws me off. thanks
Nov 4, 2006 #2 Z Zero82z Fully [H] Joined Jan 20, 2004 Messages 27,897 Core is the 3D clock, which should be set to 450. Memory should be at 550. However, there is no guarantee that you will be able to stably run at those speeds.
Nov 4, 2006 #3 J jordan12 [H]F Junkie Joined Dec 29, 2000 Messages 11,105 One last thing. How can I determine what the card is running at currently?
Nov 5, 2006 #5 Z Zero82z Fully [H] Joined Jan 20, 2004 Messages 27,897 What are you using to overclock?
Nov 5, 2006 #7 A Arcygenical Fully [H] Joined Jun 10, 2005 Messages 25,066 Is it not listed RIGHT beside the slider?
Nov 5, 2006 #8 Z Zero82z Fully [H] Joined Jan 20, 2004 Messages 27,897 Arcygenical said: Is it not listed RIGHT beside the slider? Click to expand... Should be...
