D
Deleted member 218490
Guest
Are there any motherboards with a powerful enough onboard video to support 1080p playback?
Spam?
Check out all the threads by the OP -- seems like a lot of "are there<insert random question> <insert insert topic relating to forum topic> " that would easily be covered by a sticky or a quick google. Almost like someone trying to bump their post count for some weird reason... I hope not, though...
It maybe outdated but it gives you a general idea and its only 6 months old. It hasnt really change over night
I should have known this forum would waste posts flaming rather than saying yes or no like user "450" did. Some of the motherboards listed in the Ultimate HTPC thread are no longer in stock, some are discontinued, etc.
Searching for information isn't always adequate since posts more than 6 months generally contain outdated information.
No, im not. I'm bored at work and researching some HTPC info for a future build I plan to make. Checked out a few other threads and posted along the way. Relax. I've only posted one other "question"
Just get an H55 chipset motheboard with one of the core i5 cpu's
No offense if you're intending to stick around for the long haul. Since some forums have post requirements, we often see threads that are pretty generic like yours was and it's only purpose is to raise a post count.
Welcome aboard.
No, you're right, it hasn't changed significantly but I didn't see any harm in asking for some fresh insight to the matter. I've already got the answer I need above so I guess we're done here. Thank you.
OP, I just built a super budget HTPC using an ASUS M4A785-M board (AMD 785G NB & HD4200 GPU) and a 2.9GHz X2 245. With 2GB of DDR2, and a old IDE 250GB that I had sitting around, it runs 1080p very smoothly, and does digital audio over HDMI. Works pretty well.
