Onboard USB not working.
Dethred
Hey guys,
I noticed that my onboard USB device isn't working on my motherboard. I have everything having to do with the USB hub enabled in the bios. What else could I check before I RMA the board?
Also is it the integrated usb ports on the back of the board or extra ports that you have to plug in to a port on the board?
look in the device manager and see if any devices have the little yellow exclamation mark of doom.
check bios to make sure that they are enabled. probably in something like "onboard devices" if yes, try the other speed - if enabled on usb2, switch it to usb1. also, in the device manager/usb root hub/power management, uncheck "allow the computer to turn off this device to blabla" . do this to all the hubs. then reboot.
i have the exact same problem, usb seems to be not powered, no idea what causes this (i have a p5b-e mobo).
everything else works fine though, shame not to be able to use my copperhead mouse and my ultra x kb...
i have twiddled every bios setting, even there the kb is never detected...
so feels like a rma to me... brand new mobo :(
my gear:
6600 duo
8800 gts
650w cooler master psu (so i guess it's not the problem here)
Look at the device drivers for the mouse first. It's not standard and those have to be installed.
Second issue might be conflict between USB 1.1 and USB 2.0 protocols.
Third issue, though unlikely, is that you have a raw windows 98 install and you haven't installed the separate USB drivers.
my gear:
6600 duo
8800 gts
Hey I have the same problem. It resets my 518 and it starts going SLOW in games or in the desktop at random. I set it high so it is very noticable. Reinstalling the mouse shows the correct speed for a few minutes.. Something turns off the mouse acceleration in game as if it is using the os vs. the setpoint which is all on in the task manager. Going in device manager shows no yellow. Going to the Bios shows it is powered not high but using the number 480 or whatever it said. I have checked everything, reinstalled the mouse a few times. Am sick of the bloody voltage changing. I would go in game and it would decide to either go super speedy fast acceleration or off by itself heh. The slowpoke behavior would mimic that of going on top of a file and stopping like smartmove despite it was not checked in the setpoint. Game settings inside of setpoint were correct and the same as the old system. It would be insanely slow in the desktop despite SWITCHING usb ports. Was using the ones in the back. Hope I can RMA this in time tomorrow.
Not sure if HID is always supposed to be enabled for mouse but I noticed also this mouse seen as HID. I think in the past I had a gaming keyboard set as HID but never had to have my mouse set like that.
:mad:
