onboard sound fun
blacklimo03
Ok, I am pretty sure that I understand this problem. The onboard sound requires more of the CPU's power, which causes it to slow down performance. Is this correct? Thanks for your time.
Well, it will. But a very tiny amount, and its more a MOBO chipset usage then the proc itself. Either way, it will make a very miniscule performance difference if you use it or disable it. (speaking strictly of game performance, not sound quality)
Yup, makes virtually no difference. It's not like the drain WinModems had (don't want to say have, nobody uses these anymore, I hope!) on the system bus.
I use the onboard sound on my main gaming desktop cuz that's all I need, but on my HTPC (not in my sig) I have an audigy 2 plat.
It's all about what you want to do :)
This might just be an odd, one time deal, but I was playing Counter-Strike online thru Steam and I was at or around 60 FPS. Now I know that the human eye only sees around 30FPS but it was disconecerting. I was also listening to Winrip by Intervideo. I installed my Sound Blaster Live 5.1 and my FPS went up to 99. Although, now whenever I join a server, even though I am in the middle of a song, a new songs starts playing over the current song?!?!!?! It is very strange.
