Onboard sound and CPU performance
UltimateMan
Alright, I just saw some numbers from the [H]ardcore:rolleyes: website of gamespot.com
http://hardware.gamespot.com/Story-ST-x-1240-x-x-x&body_pagenum=8
that basically shows serious FPS decreases in HL2 with a computer using onboard sound as compared to a computer with a nice soundcard. Now this makes sense to me, and i am currently using onboard sound, but I was curious what you guys think of this and if you have any other site references documenting or testing this.
THANKS!!
it wouldn't be near that drastic at lower levels, besides, there isn't much of a difference between 75 and 65 fps, so whatever. at least the onboards sound is free
A friend of mine could hardly run Doom 3 on his system with the on-board sound (P4 system) but once he upgraded to a AudigyZX, he could run it no problem. I had a problem with a Asus P4XP-X mobo that would randomly lock up playing Doom 3, but a dedicated sound card worked great. As far as on board sound has come, it still isn't there.
I think most mobo reviews [H] does run tests +/- audio to see how bad the on-board audio kills you. Howerver, it's not quite what you want because they don't actually replace the sound card, they just disable/enable it.
