I've got a MSI K7N2 Delta motherboard with a built in Promise FastTrak 376 RAID controller. I've never used the RAID functionality of the motherboard before but I've been using the motherboard for about a year now.
I just bought a new hard drive that is the same model as one I currently own, my plan was to mirror the two 250GB drives using RAID 1. I've been trying without success to make this simple seeming feat happen.
My computer has 3 hard drives, 120GB + 250GB + 250GB (the new one). The motherboard has 2 IDE channels + 1 IDE channel for the RAID part.
The first thing I tried was plugging my 120GB hard drive, set as master, into IDE 1 on the motherboard. I set the 2 x 250GB hard drives as master and slave and plugged them into IDE 3, the differently colored RAID one. I booted up the computer, hit ctrl+C at the appropriate time to enter the RAID BIOS, and selected the option to view all drives. It only showed 1 x 250GB hard drive as master, on IDE 3. Neither the new 250GB nor my 120GB hard drives showed up.
I then tried switching which of the two 250GB hard drives was master and slave, and I used a different IDE cable. I left the 120GB as master on IDE 1. I booted back up into the RAID BIOS and it still only showed 1 x 250GB drive as master on IDE 3. I turned off the computer and plugged the 2 x 250GB drives into IDE 2 as master and slave. I powered back up and went into the normal, not RAID, BIOS and it showed the two 250GB drives on IDE 2 as master and slave.
So then I tried plugging each hard drive into an IDE channel while set as master; the RAID BIOS still only shows 1 x 250GB drive on IDE 3.
Did I miss something simple? This is my first time using RAID, what's going on? Any advice on what to try next would be great. Btw, the motherboard manual, raid controller manual, and manufacturer websites were useless...
