Onboard LAN...what is it?
Headbust
sorry if meh sound retarded for the proposed question. Anyway, is it just a ethernet card(cable/dsl) on the mobo instead of a PCI slot?. I have a few ethernet cards laying around so if i dont need the onboard lan on my mobo that im about to order id rather not
It is an integrated network card built into the motherboard to save you a pci slot.
thx man, so i dont need it really since i have a ethernet card already right
I would get it anyway. Most motherboards include on-board LAN, even the sub-$90 set.
well my spending limit of $1200 is being cut down to about $850(because there is a 47inch HDTV im getting today, the only way i can get it is if i get the prices down of the pc im putting together).
The only games i play right now are Half-Life and its mods. So i really dont need to go overboard on video and stuff which is saving me alot of money.
One last question...A power supply that i used my 845PE board will work in a 865PE board correct?
Yes, the power supply will work.
Believe me, any motherboard worth getting will come with it - on-board lan adds less than a dollar to the cost of the board. Prolly closer to a quarter.
My question is why don't they include an on-board modem....save another PCI slot for those still on dial up
Nobody pities those still using dial-up that much.
I think the reason for that is driver development for 56k is a little more complicated compared to a nic. That raises the costs a couple bucks, and you can only pack so much onto a mobo pcb. Nowadays pcbs look pretty crowded.
In 99.9% of cases ive seen onboard lan works fine.
Our old packard bell 386sx had an onboard modem. Well not really. It was just a tiny little board that hooked up to the motherboard with a ribbon cable. It didn't take up any isa slots(no pci back then). Onboard network is probably a lot more useful than onboard modem because the people that the onboard network really benefits is the people building hundreds or thousands of machines to hook up to a network. Save $20 x however many computers and that's a lot of money. There's not as much of a cost benefit for putting onboard modems, since that's mainly a single user thing. I like having onboard lan though. Saves a precious pci slot.
I love onboard LAN, saves a PCI slot and with my IC7-Max3 it came with Gigabit LAN (10/100/1000), even though i haven't been able to utilize the "gigabit" part of it though
I dont understand what everyone complains about PCI slot usage for all the time. WTF do you guys put in all these slots?. Most boards come with at least 5 PCI slots.
All i can see using them for are
Ethernet card
Sound Card
56k
I have no other use for the other 2-3 that are left for what i do.
Ethernet card
Sound Card
56k
Hard drive controller
Hauppauge tv tuner card
Turtle Beach Santa Cruz
A couple video cards(in addition to my agp card)
Basically, if there's a slot I'll put something in it.
HD controller, heard of it but never new it took up a PCI slot, whats it do anyway.
Probably 1 outa every 200 people use them up like you do
It's an IDE controller. You hook up hard drives to it. It controls the hard drives. I have six hard drives and two optical drives, so I need the extra ports. A lot of people use pci ide controllers in raid situations and in situations like mine when they have more drives than channels on the motherboard. Also, older motherboards don't support some of the new, large drives, so the pci controllers allow you to use those drives with older motherboards. Older motherboards also don't support ATA100 or ATA66 or whatever(depending on how old it is), so pci ide controllers allow you to use new drives at their designed speed. It's a pretty common thing, and some hard drives actually come with ide controllers in the box.
Ethernet card
Sound Card
56k
:rolleyes: Yeah, since you don't use anything but a soundcard and a modem you can't conceive of anyone else having needs other than yours. Even if you do have 5-6 PCI slots sometimes you cannot even populate them all due to IRQ sharing or BIOS issues with the PCI bus itself.
It takes a bit of a 'power' user to fill up one's PCI bus completely, but it's not altogether too difficult. Factor in the numerous expansion headers that don't take up a slot in the motherboard, but do take up space in the back of your case for extra USB, sound or firewire headers and things can get pretty congested back there.
hey cmon man. I still have dial up because I'm forced to.... no broadband available in my area. Satellite broadband is sucky at best too.
I'm currently trying to figure out what I should do because all my pci slots are taken up...:(
1. Taken up by the fan on my gf4 ti4600:(
2. Creative X-gamer sound card
3. Ethernet Card
4. Sata controller card
5. berklin 5 port usb 2.0 card
I need a firewire card for my camcorder, but I just got my usb card for like $30. Maybe I can sell it to someone:eek: BTW I had to take out my 56k modem and my tv card. I wish mobos came with 8 pci slots, then I would be happy.:D
3. Ethernet Card
Get a motherboard made in the last couple years and it'll have ethernet, sata, usb2, and firewire. :D It'll even have sound, if you're that tight up for slots.
pci slots can be used for extra video cards, extra NICs (for turning a comp into a server..), modem, sound card, USB cards, firewire cards, lots of specialized crap... like ieee cards for connecting oscilloscopes or something like that, there's a billion things to plug into PCI slots.
why make primary nic another one?
you can even put fans in the PCI slots...
and they dont have onboard modem cause most users won't use them, where alot will use the onboard lan, if not for broadband, then for networking at some point or another.
Some company makes a breakout box with way too many pci slots, not sure who.
Even though the motherboard has onboard firewire and sound and stuff, a lot of them (like the a7n8x deluxe) still have brackets that don't take up a slot on the motherboard, but take up one on the back of the case.:( I nerver got the point of that. Unlike my chaintech where all the ports are on a little cmr card in the bottom slot of the board.
-Originally posted by jpmkm
I'm going to venture off-topic here, but did anyone else start laughing hysterically when they read this?
I know I did, but I'm a sick mofo.
Think of it this way...as important as you feel you are as a home comsumer, to the major corporate powers that be and decision makers behind the design and manufacture of PC components, you really don't factor into the equation all that much. In designing something, like a motherboard, with onboard components business requirements are going to be weighed much more heavily than home use. No major corporation is going to outfit their 300+PC headquarters with 300 machines on 300 dial-ups with modems. They will, however, want to network all their machines. New ISP sales are headed to broadband style connections. These use ethernet (or in some really less than optimal solutions, USB) connections to communicate with the devices.
So it comes down to a business decision and what makes sense. As much as you might like to think that your needs are right in line with the designers, including onboard modems on PC motherboards ranks right up there with left-handed mice. There may be a need or desire for them, but not enough of a demand to make it a smart business decision.
haha...i see where ur going wit that but its a bit nasty
i got six PCI and one AGP..only got room for one more....
1- taken up by fan from AGP card, mite be able to fit in another card but the fan wont be getting much air
2- tv tuner card
3- some soundblaster card
4- modem card
5- NIC
6- is free not sure wut to stick in it
I thought exactly the same thing!!!!
L33T H@x0Rz Ru13Z
:D :D :D Don't worry guys, I was thinking the same thing.
