onboard LAN Vs. PCI card
Turkish621
Ok, So I play alot of online games, mainly BFME2. A friend of mine plays with me at my house so we are hooked up to the same router. Now his computer is not as fast as mine, but he usually loads the game faster. Would buying a pci lan card improve my load times? Also, I have my game loaded on my 10k raptor, and he has his on a 5400rpm laptop drive.
I don't believe so. Network cards have negligible effects (if any) on single-user applications.
Are you sure you are both loading the same textures, same resolution, etc?
Your system should obviously smoke his if the rest of his system is like the difference in the HDD's.
Load up his settings on your PC and then join the game. See how much that changes things.
edit: depending on the generation of his HDD, he might be using a lappy drive which has higher platter density than your raptor. Even though you have 10k RPM versus his 5.4k RPM drive, he might have higher data transfers than you do. In that case, its your raptor thats to blame. The 36gb raptors were great back in the day, but most last-gen 7.2k rpm drives sporting the 8MB cache were almost as good and current gen 16MB cache 7.2k rpm drives smoke those original raptors.
Onboard NIC's wouldn't have much effect on load times. They are usually lackluster performers and will offload more work to the system CPU, but not really enough to noticably increase load times.
sniff, I know my poor raptor needs to be replaced... Yeah, I guess I never thought about resolution size. I will have to see what he is playing at. Thanks.
This may be a stupid suggestion, but when my load times are getting long, I do a thorough defrag - and it usually helps a lot!
Its not the resolution I would look at, but I would go for texture size (I've never played that game, but look for texture sizes, what kind of eye-candy he has loaded etc).
Listen man, I'm not knocking your raptor, but if your friend has a new generation lappy drive (and I dont know he does) it is very possible he just has a higher data throughput than your raptor.
If he has one of those Quantum Bigfoot drives from 1998, he's definitely tweaked his settings to get the load times....
