onboard lan now blinks? wtf? please help!
G'ßöö
I have a DFI lan party ultra D and was cleaning the keyboard when all of a sudden it went into suspend mode. when I brought it out of suspend mode the built in nic won't connect. it blinks on the nic itself and router. in windows (sys tray icon) its trying to intialize but toggles between disconnected and attempting. what the heck is going on? I've traded keyboards and its still the same. I can only think I've put the nic into a suspend mode. can someone please shed some light before I have to buy a pci nic? Thanks in advance!!!
Try this, go into your bios and disable the nic, reboot the pc and then shut it down and then re-enable the nic and boot back into windows and let the nic be found again by windows and see what happens.
I should have mentioned I uninstalled, de-activated in bios/reinstalled. its still a no go. all nic options for power or wake on lan have no effect. I am using my ps3 to write this so my .net/router/cables work. I even started mashing the keyboard again in a desperate act =P ...I am at a loss
