MazerRakham
- Feb 22, 2012
I recently purchased a motherboard that has a DC power in jack:
http://www.gigabyte.us/Motherboard/GA-H110TN-GSM-PLUS-rev-10#ov
My case also came with a DC to DC power board (meaning it had its own power jack) and I was going to connect that power board to my motherboard via a 4 pin ATX connector.
Unfortunately, I can't get the motherboard to power on using the power board that came with my case. I can get it to work if i plug it in directly to the motherboard.
My question is, will it hurt my motherboard long term if I use the on board power system over a separate one (this is going to be on 24/7)
Thanks.
Thanks.
