On the Apex kit...
Yes, you will need at least 2 holes cut in the case for the tubing if you plan to mount it outside the case.
aha! you only one big hole! :p ;)
Two is better than one................. :p
Just make sure your case has a 120mm exhaust fan on the back, otherwise you'll have to drill mounting holes for the RadBox that comes in the kit.
The rad box WILL mount on any sized rear exhaust mount.................. :D
"Note that a chassis with 80mm fan opening(s) is likely to provide a very good range of adjustments. Conversely, a chassis featuring a single 120mm fan opening the base-plate is a direct bolt on, but offers no adjustments, which may or may not suit our installation for the purpose of positioning the radiator. In that case, it will be become necessary to drill (4) mounting holes of 0.150” (~3.5mm) in diameter to install the base plate at the desired location."
http://www.swiftnets.com/products/installation_guide_h20-APEX.pdf
You can actually mount it on a 80mm as the radbox is adjustable.
