Yesterday, a new case that i ordered arrived, together with a new CPU. I install everything and the PC would power up and then power down on its own after a few seconds. I went bananas. At the end i discovered it was a defective power switch cable on the new case. I believe that somehow it keeps sending signal, so the first time it switches on, but as it continues, the PC auto-switches off.
Now, i went from noon till 01:00 AM until i figured that out. I took out the mobo, banged it, reattached, de-attached everything multiple times, installed-uninstalled heatsinks. To add to the drama, i try to put everything back to the old case and... no video. And there we go again, on and off from the case, changed screws, standoffs, powered outside the case, installed, reinstalled, banged it, had it in weird angles, at the end, i thought myself "hey, after all this torture, the poor thing may have stopped working". But the cardboard box test showed it was running fine.
I 've never bent and abused physically another motherboard like that. I was so exhausted and angry last night that i didn't care about the flex, i was just putting in the cables trying again and again. I arrived to the point to WISH that it would go bad so that maybe i could justify to use one of my spares and maybe this would work.
So, morale of the story, one may think whattever wants, but after these 24h of constant physical abuse to a motherboard (that i 've been pounding 24h/7 for more than 2 years with video encoding), the "flex risk", for me, is purely psychological. I usually never treat my motherboards like that and i doubt any system builder does. But i was so frustrated that i tortured that little board and it endured everything... Glad i ordered the R2.0 too...
Asrock is like the AMD of motherboards...
