OMG, toast video card???
my friend was overclocking his sapphire radeon 9800 pro with Atitool and went to 400 core/360 memory overclock with stock cooling and then we restarted the computer (also setting his barton 2500+ speed to a FSB of 200 on his abit NF7-S v2 mobo). well when we got into windows, when we go to open atitool it crashes and shows the core clock at a faded 0.00 and a memory of 0.00. then the screen goes blank and the computer restarts. i immediately go change the cpu back to a 166 fsb and multiplyer of 11 like default and get into windows. i try to open atitool and it crashed saying tons of different error messages. it finally opens and shows the same faded out 0.00s. wtf. is the video card dead or about to die? because he is actually playing call of duty as i type this and it is running fine and the fan on the radeon is running so are we okay? what is this, what caused this, any suggestions??
i think your fine, ATITool can be buggy at some tiems. did it tell you some file was damaged and said you should repair? thall mess the values upo
i think your fine mate, just reinstall the prog or unzip again and it should work, (hopefully)
it works after i updated ati drivers from 3.8 cats to 3.9s. then i reunziped. but now i am (or rather my friend) is getting ~150 fps on the 3d cube. odd
try using paragprahs and periods
its just the program, you are fine.
