gwai lo said:auto restart only flashes you the bsod....whereas disabling it will show it on the screen allowing you to write down all the information...such as error codes or which file is causing the problem..etc..etc
swirly said:djnes or w.e. i am sorry im not a lsoer that spell checks in a damn forum.. if oyu do that.. :AT ON BACK:: i feel very VERY bad for you ..
wayne said:but if your seriously bored, you can get two low power psu's and wire them together splicing every single wire and corresponding it with the similar wire of the other psu so it adds more power... however, i do not recommend this unless you have electrical experience because you may end up with more than a dead computer
you can actually, i think ive seen people do them successfully but then theres also the risks of something exploding, so i take back what i said =)mikeblas said:I don't recommend it, either. You can't gang all of the signals -- the power good line, for example.
.B ekiM
