OMG please help me I killed my computer..
virtuexru
OK, So.. I'm sitting here at a shitty PC Cafe right now. And I mean bootleg ass shit over here. My PC is dead, and I guess its my fault that I listened to my friend.
Hes a knowledgable guy, and he knows I'm getting a new computer in like a week or two so hes like yo make the most out of ur current computer and overclock the CPU (Athlon 2800 XP+)..
So he comes over, and hes like lets look through BIOS, he see's CPU FSB setting, ups it to 200MHZ from like 180 or 170 around there somewhere. Saves, Reboots, then the comp won't post boot. Like the screen just stays blank. The monitor button thing is yellow not green like its suppose to. However the system is running, all fines and harddrives are on, video card fan is spinning.
So he is like Ummmm omg lol. He turns off the comp I'm like take out the battery thing on the mobo maybe that will reset shit. No go, still the same thing. I didn't get too mad except for the fact that my mom moved out to a new apt and im staying here w/ like just the computer and a matress for almost a month till I move out to college. So if my comp doesnt work, theres nothing to do besides go out. (which I do too much of already)..
And my new comp wont come for another week cuz im waiting on all the parts. Anyway, if you can help that would be GREATLY appreciated, here are my system specs.
Old MSI mobo
amd athlon 2800xp+
2 maxtor HD's
radeon 9800pro
1 gig ram (512x1)(256x2)
raidmax power supply (350 watt)
Umm.. Thats it.
Did I fry my cpu:(?? I think thas it..
no u didnt fry ur cpu... it just needs a bios reset.... how long did u remove the battery out anyways... make sure when u do that.. unplug the powersupply ... also... try holding INSERT button on ur keyboard... and tell ur friend to go away... if he overclocked ur computer.. and doesn't know how to reset it when it's down.. he shouldn't be there...
I'll try that, i left the battery out for 5 min but I dont remember wether or not I took the power supply cord out.. I'll try holding insert too. This is such a pain in the ass, I thought that if something screwed up BIOS auto goes back to last good config, guess not.
yeah, when you unplug the powersupply, the battery only needs to be out of the motherboard for 5-15 seconds.
that'll reset the bios, and it should work fine.
and if your buddy is a "knowledgeable guy" and can't figure out how to fix that issue, like has been said before, he doesn't belong on your computer.
OK Because I took out the battery and put it back in and still no go... What happens if it still doesn't work, then I KNOW i fried something?
the bus should have been 166... and he just upped it all in 1 go to 200 from bios?
smart ;\
I fixed it!!!!
Yea, that was the only other choice lol. Anyways, I fixed it!!!!! I switched the CMOS Jumper from 1-2 to 2-3, turned it on, off, then reset it. Fixed! Bios post boot and I reset all the settings to normal.
Thanks for all the help guys..
ever since like 1998 the purpose of the battery was just to keep the clock moving, there should be a little jumper some where on the lower half of the motherboard near either the bottom edge or right edge some where just move the jumper over one pin then move it back
If you know the exact model of that MSI board then we could tell you where the jumper is.
google link for ideas
EDIT: doh just a little bit too late
virtuexru said:
I fixed it!!!!
good job!, now come fold: www.hardfolding.com
virtuexru said:
I fixed it!!!!
lol good thing.. I was about to give u some bad news about some athlon xp and some boards that didn't like the 166 to 200 right away and caused an instant cpu death :p
