Feb 22, 2005 #1 B Brantoc Limp Gawd Joined Nov 8, 2004 Messages 386 How the hell do you OC the newer Nvidia's? Ok.. I've been using ATI's for the last few years.. Nvidia's had it in the driver right? a Registry key change allows it right? Been too long..
Feb 22, 2005 #2 M majorwoody Weaksauce Joined Oct 26, 2004 Messages 87 http://www.guru3d.com/rivatuner/
Feb 22, 2005 #3 A Absentee [H]F Junkie Joined Aug 27, 2004 Messages 9,410 or google a thing called coolbits to enable it in the driver as you said...
Feb 22, 2005 #4 B Brantoc Limp Gawd Joined Nov 8, 2004 Messages 386 Yep.. I found coolbits on my old external 60gig I never use anymore was from .. like.. 3 systems ago.. anyway.. Geforce 6600 PCI-E @ 561/1120Mhz Thank you kindly
