BillR
Born Again Cynic
- Feb 17, 2002
Ok been running this system in my sig for a while, and then all of a sudden when I play a media file it hardlocks for no reason with the speakers making a loud humming noise! This is getting ridiculous, does nvidia not care about the quality of their chipsets -- I cannot even fucking upgrade to 780i b/c stability issues are reported on that POS as well!
In addition to that going to X38 will cost ~1300-1500 since I water cool all parts on my systems and have 3 displays I would need 2x 3870X2's as well.
I guess I am stuck with this shitbox for a couple more months (8800 GTX's aside)
Back on topic maybe?
First, loud audio hum. This is almost always and indicator of a bad ground, usually the connectors between your speaker system and your sound card or motherboard sound inputs.
Its also possible your speaker system is leaking DC back into the system.
Unplug all usb and audio cables and see how things work then.
Luck
