You mean nvsc is a non legit prog? I do have some nvidia software installed; such as msi core center (for overclocking and temps).eno-on said:/edit : made mistake, nvsvc32 is fine, nvsvc is not.
xXaNaXx said:to Metallica_Band:
Step 1: set a **good** BIOS password.
Step 2: set a **good** administrator & user account password.
Step 3: **DON'T** run your system 24x7 logged in as administrator if it's publicly (or even semi-publicly) accessible.
Step 4: **always** lock your workstation when you're not using it.
nvsvc32.exe is legitRumrunner said:You mean nvsc is a non legit prog? I do have some nvidia software installed; such as msi core center (for overclocking and temps).
BIOS password is crap...even *I* can bypass a BIOS password...hell, you can even do it by only getting into the casexXaNaXx said:Step 1: set a **good** BIOS password.
Again...well...atleast on the ones before XP, they are easy to bypass...but I'm not sure about XP...never tried it out before...xXaNaXx said:Step 2: set a **good** administrator & user account password.
I always run my system 24/7...I have it do things when I leave...run tests, dl stuff, antivirus, defrag, etc...xXaNaXx said:Step 3: **DON'T** run your system 24x7 logged in as administrator if it's publicly (or even semi-publicly) accessible.
How would I lock my workstation? Ummmm...what's a workstation?? The whole case?? I can't do that cause there's no ventilation...I've got a powerful PC and it needs cool air to survive the harsh FL heat...xXaNaXx said:Step 4: **always** lock your workstation when you're not using it.
XP Professional has a lock so you have to log back in. Windows Key - L, or CTRL-ALT-DELETE Lock Workstation. You really think a keylogger is gonna tell you who's on your box? If your worried about someone bypassing ordinary means, then I'm sure they can bypass a keylogger.Metallica_Band said:*Snip*
I'm not saying that I won't do any of the above...but addding a keylogger doesn't create any kind of trouble for me...just dl, install, and run when I leave....it's just another layer of protection IMO...IF someone figures out how to bypass or hack my passwords, then I will at least have a little program hiding in the dark corners of my OS spying on who is messing with my computer...I'll at least know what went on when I was gone...
Metallica_Band said:BIOS password is crap...even *I* can bypass a BIOS password...hell, you can even do it by only getting into the case
The Geek Squad is considerably less able to help fix the problem than the guys here. However, if all you want them to do is reformat, then they should be able to handle that.j4zzee said:Its going to be OK; please take a few steps back from the computer.
Pick up you phone and call the Best Buy Geek Squad
Peace in the Galaxy will be restored.
yes... a high level and low level format is in order...GreNME said:The Geek Squad is considerably less able to help fix the problem than the guys here. However, if all you want them to do is reformat, then they should be able to handle that.
Goride said:Im guessing its fake too...
I suppose i could be wrong, but how often does a real program for hacking come right out with a pop-up message and be like "omg you have been haxored."
( + exageration)
