CorporalStorm
- Sep 21, 2005
This is startin to tick me off.. Anyone ever had Modders Block? LOL. I'm having a helluva time trying to find a case I want to use. I had planned on the SViking from ThermalTake but I just found out that the p0s Fan Controller Module only works with the fans that come with the case so if they go out and I cant find the same ones down the road. I'm stuck with a dead intergrated Controller Module. So then I moved over to Antec LanBoy Super, ugh Silver ugly. Next. So then I looked up AeroCool's Jet Engine Turbine looking one with the 14CM Fan in the front. Pretty spiffy if you ask me. 2 120mm Fans on the side door, one in the rear, decent room. Downside, Plastic Doors (Break too easy), and everything is screwed. No Tool-less design. So now I'm up a creek without a paddle. My case is bout done for, the front is held on by SuperGlue and its just a rather p0s case. It got so bad I had to take the side door off and stick two desk fans to blow right on my Vid Card/CPU because the case would attract so much freakin heat.
So any suggestions on a decent case?
