Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
There's nothing bad about them I've ever seen. Once in awhile some versions are said to be slower than an ATi version, but that is because of fixes that are made for better image quality and more stability. Plus, up until the latest version, it came with a nice OC utility(RadClocker) that showed itself as another tab in your display properties instead of looking like a whole separate program. You can download the older drivers, install just the RadClocker and then install the newest drivers if you wanted that feature/program with the newest driver.
