Omaura TF8 Question
Hey a friend of mine is offering to sell me his TF8 for a good price the only problem is the power light is dead... is this something easy to fix ?
Also can a Omaura TF8 take a full size CD-Rom drive and not a slim drive? Let me know guys THANKS!
tried google everywhere i go says something different. So sites say both slim and reg some say just slim some say just reg. I thought i might someone that put a tf8 together first hand. And there isnt even a clue on what kind of led th power light uses.... or if it even is an LED
Second page of first link on google search "Omaura TF8":
http://www.cpu3d.com/review/2336-2/omaura-tf-8-htpc-chassis/features-and-specifications.html
All you can install HTPC style
Four low profile expansion cards, a full ATX power supply, a Micro ATX motherboard, four hard drives, a full size CDROM. Want all this in your living room? Expect its going to consume a good portion of it in the process? The days of mainframes taking entire rooms are long gone, so too are the days of having a 15cm tall HTPC enclosure capable of handling the hardware you want to get the power you need. The TF8 is capable of housing all the hardware that a high end media center requires.
Drive Bays External 5.25" 1
Drive Bays External 3.5"
Drive Bays Internal 3.5" 4
As far as the light goes. it is probably an LED and you will probably not find any information anywhere on earth about replacing it. You will have to see the case and find the LED itself then find a replacment. I would be very suprised if the LED is dead. More likely the cable is broken or installed wrong. I have never seen a dead power led itself, always a broken or incorrectly installed cable.
