Olevia 37" LCD , thoughts ?
yeah i would go with the westinghouse its an awesome tv/lcd monitor 1920x1080 resolution -sick
Depends, the westy is full hd (1080p) while this only does 1080i. Its up to you whether youll need/want that feature? Planning on HD-DVD/BlueRay? Getting a ps3? The 360 outputs in 1080p after the fall update now.
Sure the westy is 300 more, but the question is are the extra features worth it to you. Keep in mind the westy is just a monitor and has no built in tuner.
The westy has had huge praise both on here and avs forums. Just scroll a bit down and you'll see numerous threads.
