Because of poor yield.
SED was the ultimate display but it never came around.....too bad really.... now we have this over hyped OLED which looks great but it's not for everyone.... LCD isn't bad if you get a good monitor....
Why not?OLED which looks great but it's not for everyone
Yes it is....LCD isn't bad....
Both FED and SEDs are essentially flat panel CRT with fixed pixels and are inferior to OLED.Wasn't SED basically a thin ass CRT?
Why not?
OLED: Work out the longevity issues and this is near perfect display tech. Pure black, pure speed, pure viewing angles.
In my opnion, LCD is fine for computing but not so good for a home theater setup. The true constrast ratio (not the dynamic one used for marketing purposes) is still quite bad except maybe for led array with local dimming.
Korean Panel Makers Change TV Priorities: OLED vs. 4Kx2K
A fundamental challenge for AMOLED TV remains manufacturing yield. Pilot production indicates that 55 AMOLED TV panel straight yield (without repair) is in single digits due to instability in the large backplanes (using LTPS or oxide TFT). Total yield (after repair) is estimated to be less than 30%. Finally, frit encapsulation is too fragile for large area TV, and is resulting in reduced panel life.
http://www.bbc.co.uk/news/technology-20888689
LG finally launched the 55" OLED. If you have the money, you can import it from Korea
how would an OLED monitor do in terms of response time and input lag? would it be suitable for gaming?
That is patently false misinformation, Nielo TM. In fact, that is so incredibly foolish I've got to believe you have some sort of ulterior motive in stating it.
OLED doesn't have the same problems as LCD tech so there would be NO motion blur, no need for image processing so no input lag (although I can imagine some companies will put image processing into some units) and no ghosting.
So is plasma. The only difference is plasma uses UV where SED uses electronsSED being basically a flat CRT would have had impressive motion clarity.
You can argue the benefits of other technologies, but where motion is concerned the death of SED is indeed a tragedy![]()
For stating Panasonic plasma is becoming on par with SED?
You do realize the 2012 models managed to reach ANSI black level of 0.009 cd/m2 and the 2013 models are expected to reach 0.005 cd/m2 (on par with the SED demo unit). 2012 models also yielded 1080 lines of motion.
Oh wow, black level and 1080p. /facepalm.
Motion clarity. Zero trails or overdrive errors. Analog signal. No sample-and-hold smudginess. Adjustable refresh rate.
None of those things must matter to you.
SED is the ultimate display technology, as any informed member of this forum will tell you. Plasma and OLED are undeniably superior to LCD, but they have their own disadvantages. SED took the disadvantages of CRT and completely erased them.
Lets keep the discussion civil wabbit.
My 2012 Panasonic Plasma may yield 1080 lines of motion in some tests, but the long phosphor decay make it painful to watch at times. Like an LCD with excessive overdrive, the faster you pan the more painful those phosphor trails become.
While OLED is wonderful, this is unfortunately inaccurate.OLED has response times and input lag like CRT, so it would be much better than any LCD or plasma. And not a hint of ghosting.
RIght, but keep in mind that a 1:1 black frame insertion would only reduce motion blur by 50% (one black frame between every frame).OLED displays are based on Active Matrix, which do blur. Thankfully it can be removed via pulse emulation. Basically inserting black frame between every other frame
For sample and hold displays, 0ms instant pixel response is NOT zero motion blur
BlurBusters.com Blog -- Eliminating Motion Blur
