Older system locking up under heavy I/O
venm11
Hi folks
I've got an older P4 dell (dimension 4400 + XP) which looks like it's locking up under heavy disk access. By locking up I mean that they keyboard/mouse/video become unresponsive. This is particularly true when copying files to a USB drive -- the keyboard/mouse (possibly video) will only respond once every 3-5 seconds.
Disk performance on this system is suspiciously low to begin with, and the system along the lines of what you see when using PIO (but it's on DMA). When I plugged in the USB drive, it becames far worse.
Anyone had this problem? Because this is a dell, I don't have much control over IRQs and stuff like that. But maybe this indicates that a proper driver isn't present, perhaps for USB or IDE ?
Update: What's actually happening is the ps2 keyboard and mouse are shutting off during these times. The numlock light goes out and the mouse LED light goes out (or half-dims) when the IO load gets too great. Bizarre!
Hi folks
I've got an older P4 dell (dimension 4200+ XP) which looks like it's locking up under heavy disk access. By locking up I mean that they keyboard/mouse/video become unresponsive. This is particularly true when copying files to a USB drive -- the keyboard/mouse (possibly video) will only respond once every 3-5 seconds.
I also had this problem in spades :mad: on one of my older systems, a dual-Athlon 2000 + (CPUs modded for MP operation, been running OK like that for about 6 years now). Motherboard is ASUS A7M-266D. Very stable. 3 GB Crucial RAM, ECC. Still great for a backup system, running Win XP.:p
When I first built up this system, I used SCSI drives and I/O was OK. But when I upgraded to SATA, using an Adaptec board, I started getting these same problem.:mad:The Adaptec board is a PCI-X, plugged into one of the double-wide PCI slots on the motherboard.
Hope this helps.
x509
Hope this helps.
x509
Did you investigate IRQs, PCI burst length (i forget what it's called)? Is it the PS/2 problem I'm describing in post 2, or is it just locking up the computer?
i was thinking bad HD, which it might still be, but that wouldnt explain the poor usb performance (althought it could be bad as well) whats your southbridge temps like? i realise it probably dosent have a temp probe, just stick your finger on it and tell me if it is noticbly hot to touch.
have you tried reinstalling the chipset drivers?
Honestly not. :( But this is a backup system at this point, so I simply accept the fact that when I do a big disk-to-disk copy or move, the keyboard and mouse will pretty much be useless until the disk I/O is finished.
One point though. I have a Logitech wireless USB KB/mouse on this system, with a wired PS/2 mini-keyboard as backup, since the USB isn't supported in the BIOS. (real old system.). The PS/2 doesn't freeze up as much as the USB does, so maybe it's an IRQ issue. If that is the case, is there a "quick fix" in the BIOS that might eliminate or minimize this problem?:)
x509, if you have pci-x, your mobo might have a split PCI bus. This at least might allow you to separate the ps2 and sata (raid?) cards, in case the sata card is saturating the bus to that extent. A properly located pci usb card might do the trick. The usb mouse probably has a much higher sampling rate than the ps2 does (do you use the same mouse with a ps2 adapter?)
Question --- have you ever seen your keyboard or mouse lights go off during heavy load? I'm guessing that yours is a different problem.
Thor-- that's an idea... I'll have to check that.
update: I added a second harddrive and put swapfile there, and haven't seen this problem since. Of course, that's not fixing the problem exactly...
Venm11,
I've never noticed the keyboard lights go off during disk I/O, but the main keyboard is a Logitech wireless USB with no LEDs. My backup PS/2 mini-keyboard does have LEDs, so next time I'm on this system, I'll try a disk-to-disk copy and watch that keyboard.
The PS/2 is built in to the backplate on the motherboard, but USB support is via a PCI card. Not sure about the "split bus," never heard of that one before. But I wouldn't be surprised if the PCI-X SATA card is saturating the bus.
What was very nice about SCSI is that disk-to-disk copy/move operations didn't require bus I/O. SCSI was great in its time :p, but these days, it is horribly not cost-effective. :(
Fact is, I think that this system is good only for casual backup applications, or for just fooling around with some random software, and only in XP. I'm certainly not going to spend the bucks to upgrade this system to Win 7. Maybe I should just reinstall the SCSI card and pick up some "cheap" SCSI disks off eBay. :p
