Older mobo woes
Tiny45
(UPDATES: further down, keep reading. Nothing new to see here :)
I've got an upgrade scheduled for the future, so no remarks about my board needing to be carbon-dated for historical purposes.
ECS k7s5a.
Went through about a dozen restarts when installing a water cooling system recently (no leaks or water damage or anything)
each of these restarts was start, listen for pump/feel for flow, stop, adjust, etc. Didn't have an atx dummy wire so i just did it through the board with the case power button.
Now onto the problem. Every time I boot, the board complains of bad bios checksum, and dumps me into setup. I can change everything there normally, EXCEPT the fsb setting. (which on this board is about all there is). if the fsb is at anything other than 100/100, when i save and exit i get blank screen, and after a hard reset the board is defaulted back to 66/66 (something you can't even select in the bios)... so my choices are 850mhz with all onboard crap disabled, or 1257mhz with my settings in proper.
(athlonXP 2100, btw)
All changes in the bios that DON'T involve the fsb setting, when i save and exit will work properly. just don't touch that fsb...
So, I'm thinking that a bios reflash is either going to fix the problem completely, or finish off the board and make it totally unusable.
any help would be greatly appreciated. If anyone has seen something similar before, i'd love to hear about it.
I wanna get back to doom3, but 1.2ghz ain't cutting it :(
I think the issue is AMD's p-rating. An XP 2100+ doesn't run at 2.1ghz. It processes at the power of a pentium running at 2.1ghz.(<--or something close to this.) 1.257ghz sounds about right for that chip.
no, the chip is supposed to run at 1733mhz.
When everything is working the board sees it as "AthlonXP 2100+"
right now, without being able to change the fsb, its seeing it as "AMD Athlon 1257mhz"
Right now i'm hoping someone will have seen this before and can say "Yeah, bits of hardware on the board are toast, new mobo time"
or "Sounds like a corrupted bios, reflash that sucker"
The "can't hurt to try" mentality will certainly hurt, this is my main box right now.
I'll probably flash it sometime this weekend, but hopefully someone will have more info.
(already tried running it with no cmos batt and done the clear cmos jumper dance)
update: reflashed the bios with newer and improved bios.... did squat. Actually now it's more of a pain in the ass. Before when it blackscreened while saving after an fsb change, i could power cycle and it would come back up.
Now I've actually got to reach in and clear the cmos manually since it just gets stuck that way until I do (including yanking the wall outlet)
playing around with OC utilities in windows (setFSB), I can change the fsb up to a point (setFSB doesn't have settings for over 110mhz for me.... DOH)
I'd actually be fine for a few months if I could just get it to work through software, but setFSB is the only thing that works, and the slider only goes to 110.... anyone know of anything else to try?
Using speedfan or anything else that tries to gunk with the PCI bus speeds is an insta-lock...
However when those utilities just READ the speeds, they show 36.7 mhz... and none of them have settings for that. they have 30.0 and 33.0 and 33.7, but speedfan/cpufsb don't seem to be capable of actually setting it where it is in the first place. (setFSB touches ONLY the fsb I guess, no pci speeds)
So I'm guessing that the PLL which controls my pci bus is either toast, half-toast, or just plain stuck.
There is another utility for my board called chfsb which seems to simply duct-tape the forced settings right into the cmos memory... will definately give that a try for tommorow night.
As for now I'm at 1374MHz, and fsb of 110...
I want my 133 back! :p
tommorow oughta be fun, all you folks chip in your comments and ideas during the day while I sleep and work.
thanks!
The board can take literally ANY socket A cpu...what revision board is your yours.
1.x/3.x brown to black in color
5.x red or purple color
gold or any other is a PCChips M830LR, same thing...
Sounds like you may be suffering from the "Lost CMOS" problem...some boards experience, there's an ongoing discussion at RHCF.com about it...seems like a good PSU can solve it sometimes.
Later
MD
-->veedub76 at http://p199.ezboard.com/bk7s5amotherboardforum
