This is literally my loaner machine that I give to people when they have issues or I am building them a new one. I spec it to be useful for gaming, web browsing, and all uses but not great.
As I am looking at only a board $150 or less
Canada and I would be shopping at Memory Express
Just a Motherboard
AMD Phenom II X6 1055T (90W Version)
Corsair 2 x 4GB DDR3-1600 Low Profile Kit
Corsair RM650 Power Supply
Gigabyte 750Ti 2GB
128GB Corsair Neutron GTX
240GB Kingston V300
1TB Seagate 1TB
Standard ATX Case
Samsung DVD-RW
6) Will you be overclocking?
No
As stated it is a loaner machine, it is my HTPC the rest of the time 1080P
ASAP
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Full ATX from a reputable brand (Gigabyte/ASUS/MSI)
Yes
What has happened is that the older Gigabyte GA-MA790X-UD4P which is the DDR2 AM2+ board died on me but the rest of the parts are tested and good to go. My question surrounds will this older CPU actually support the ram that I have a DDR3-1600 kit. If it posts and is stable at 1333 for example I would be fine but I don't want to purchase the board and then turn around and need a newer CPU.
Any thoughts on boards? 970 chipset should be fine but if there is something horrible about it I am OK to spring for the 990.
Thanks for the help in advance
Trevor
Just a Motherboard
Gigabyte 750Ti 2GB
240GB Kingston V300
1TB Seagate 1TB
Standard ATX Case
Samsung DVD-RW
No
ASAP
Yes
Trevor
