I just built an older rig for basically folding and light internet browsing and need some help.
I press the power button and it doesn't turn on, however if i repeadetely press it, it will occasionaly boot up. Sometimes I have to fiddle with the power supply to get it to boot. I have tried 2 power supplys and it does the same thing. The power switch is in the proper jumper location so says the mobo manual. Also sometimes it will turn on but wont post and the fans wont spin, I then reset and it works just fine. Here are the specs:
FIC SD-11 slot A motherboard
Slot A AMD 900 Mhz Thunderbird CPU
2X 128mb pc100 sdram
Ultra 300w psu
voodoo 3 pci
fujitsi 10gig
Also the computer seems to be running Slow, I know its not the fastest machine but sometimes the text on the screen is delayed when I type it.... I figured a 900mhz cpu would be decent for IE and what not....
Any comments or suggestions would be great.
-Foz
Ultra 300w psu
voodoo 3 pci
fujitsi 10gig
-Foz
