Older Asus P4T vs P4T-E
mcravenufo
Ravenufo's Macs
I am replacing my Dad's motherboard because it is basically fried.
During bootup it states it is a Asus P4T. His processor is a Pentium 1.9 but the link says it supports up to a 1.8 Pentium.
I see Asus also has a Asus P4T-E.
What is the difference between these two motherboards?
If his motherboard is only a P4T then I wonder how it is supporting a 1.9GHz processor?
If it is a P4T-E then shouldn't it show up in bootup screen?
The reason I ask is because he can't do a fresh install and I am going to replace his motherboard with the same model.
According to the links you provided the asus p4t supports 1.8Ghz + ... but both boards are differnt generation chips .. if you have the p4t its a socket 423 , so you can't replace it with the asus p4t-e if thats what your sayin . On bootup it should say down on the bottom left corner what it is (like bios date/board model/blah blah blah)
Yeah, I do know it says the model number on bootup and all it says is P4T (accoroding to my Dad). I just wanted to make sure that the "E" version wasn't just a newer model or something.
Not sure what the fastest socket 423 was when the P4T was released (1.4 or 1.8 maybe) but later BIOS updates provided support up to 2.0 Ghz, the end of the socket 423 line up.
I've still got a P4T w/a 2gig Willie in it. What happened to dad's mobo? Plz tell me it wasn't cap leakage.
I am still not completely sure what happened but I currently think it was the power supply that fried it. Are these motherboards prone to cap leakage?
I wonder if I will be able to install his 1.9 if the motherboard doesn't have a bios update.
Not to my knowledge. Just that the P4T is from that era - 2001 - when any mfr could be hit by the problem. Not all those chickens have yet come home to roost.
Anyway, if that's a 423 pin cpu, it's hardly worth bothering w/trying to find a mobo w/which to check the chip. I'm guessing they'd be pretty rare at this point in time & because of that, likely overpriced on ebay.
