CleanSlate
- Mar 28, 2003
I get an error on the connection of a of a lan card to my work's internet connection saying something like "IP can not be assigned from the router". There are many other computers being hooked up and unhooked up all the time without much issue.
I have tried everything with this system. I re-installed SP3, I reset the connection, deleted winsock and winsock2 in the registry and reinstalled them on the connection... I mean it just seems like there is something else going on that I'm not sure of. IPCONFIG shows NOTHING when I type it into the command prompt.
There are multiple air card connections installed on the machine but no air cards are in use atm.
I guess I should try deleting all the air card connections.
I'm at a loss here guys, any suggestions?
