hello every one.
i'm new to your forum,,, that i have reached from one of your posted threads! (http://www.hardforum.com/showthread.php?t=772307).
as i had a problem with my PC, in the same line! ,and i wonder if some one can help me?
Two weeks ago i had to flash my (giga byte GA-81945-Pro ) Mb bios after a flat battery replacement.
it all went OK and the sys requested a restart!
and that was it!!!!!!!!!!! i have never been able to get it to go again ( corrupted the BIOS).
i have contacted GB help site but the info they provided me did not help at all,,,
so i tried to buy a similar replacement Mb but with no luck.
the nearest mb that i have found and bought is GA-81915pl -G
now i have not yet installed my old SATA HDD with the XP onto the new MB,,as i have ben told i will be facing some chipset compatibility issues!
i have checked the GB comparison Sheet,,, and although the chip sets are different !!!,most of the other prs are the same.
Model GA-8I915PL-G(Rev 2.x) GA-8I945P Pro
CPU Type Socket 775 Socket 775
FSB 800/533 1066/800/533
Chipset Intel 915PL Intel 945P / ICH7R
Memory type Dual Channel, DDR400/333/266 Dual Channel, DDR2 667/533/400
Memory socket DDR*2 DDR2*4
Max. Memory 2 GB 4GB
Graphics interface PCI-Express x 16 PCI-Express x16
PCI-Express X16 (X8) 1 1
PCI-Express X1 (X2,X4) 2 2
PCI 3 3
ISA slot 0 0
AMR/CNR 0/0 0/0
VGA N/A N/A
Storage Interface 4*Serial ATA, 3*PATA (2 IDE133 connectors for HDDs only) 4*Serial ATA 3Gb/s / 3*PATA (2 IDE 133 connector for HDD only)
RAID Function Yes PATA RAID 0, 1, 0+1 / SATA RAID 0, 1, 0+1, 5
LAN Marvell 8001 Gigabit Broadcom 5789
Audio Realtek ALC850 Realtek ALC882
Codec channel 8 8
IEEE 1394 N/A 1394b
USB 1.1 Same as USB 2.0 Same as USB 2.0
USB 2.0 8 (4 by cable) 8 (4 by cable)
DualBIOS N/A Yes
Form Factor ATX ATX
PCB size 30.5*22.0cm 30.5*22.0 cm
Remark *Supports CIA2 & MIB2
so what would you guys suggest that i do to be able to install my old XP Hdd and hopefully
be able to boot safely without loosing my old data?.
your feed back will be greatly appreciated.
cheers.
PCI 3 3
ISA slot 0 0
AMR/CNR 0/0 0/0
VGA N/A N/A
Codec channel 8 8
IEEE 1394 N/A 1394b
DualBIOS N/A Yes
Form Factor ATX ATX
cheers.
