Mornin all,
My mates got an old AMD comp that he uses for the t'interent based on a cheapo PC Chips mobo with KT266 chipset...
Specs:-
Socket A for AMD K7 CPU
FSB 266/200MHz
Chipset KT266A/8235
Memory 2 x 184-pin DIMM sockets support two 2.5V DDR SDRAMs (DDR266/200)
Maximum: 2GB
It had 2 x 256mb DDR266 ram in it so i thought i'd give him a small upgrade and stuck 2 x 512mb DDR400 in to give him a gig of memory. I installed a fresh copy of xp after the memory aswell and all seemed well.
Since doing this however, he's been complaining of slow downs and that doing more than 1 thing at a time can cause the comp to freeze for a bit. Granted its not the fastest machine but for the internet it should be ok.
So is the memory having compatibility issues? Is it too 'fast' being DDR400 rather than 200/266? Or do i just need to adjust timings etc in the BIOS (which im still a little green at)
Any help or knowledge would be appreciated.
Specs:-
FSB 266/200MHz
Chipset KT266A/8235
Maximum: 2GB
